Use the following procedure to remove a software build for the switch.
You can install a maximum of 6 software releases on some switches. When the limit is reached, you are prompted to remove one release before you can proceed with adding and activating a new software release.
On the 5320 Series and 5420 Series, you can store a maximum of 2 software releases. When the limit is reached, the software displays a confirmation to overwrite the non-primary release before you can install a new software release.
For more information, see Upgrade the Software.
  1. Enter Privileged EXEC mode:
    enable
  2. Remove the software build:
    software remove WORD<1-99>
Switch:1>enable
Switch:1#software remove w.x.y.z
